jwillo
The Aerocatches are now on the boot. This solves the electrical problem of the boot not unlocking.
It was a slightly odd feeling cutting holes in to the boot lid.
@EthanMenace and I spent ages trying to work out if we should attach the brackets to hold the pins to the boot first, or put on the Aerocatches to the boot lid first and make the pins fit to the Aerocatches. Eventually we decided to put on the Aerocatches first as the pin brackets looked adjustable enough to make them fit to the catches.
We looked at photos of other Clios to work out where the Aerocatches should go on the boot lid and then decided to put them where we thought they looked like they were in the best position.
After creating a stencil we then attached it to the boot lid and got out the Dremel and the grinder and started cutting.
The sparks did make me wonder if we had lost our minds mangling a perfectly healthy Clio.
The Aerocatches were attached to the car with a good amount of sealant and then holes were drilled for the 6 screws for each catch. Once the catches were on we moved on to the pins.
After a lot of fettling the pin brackets from No. 7 Motorsport were attached and sat in the right position.
The Aerocatches look okay, but there is far too much chrome on the boot so at some point in the future the chrome badges will come off and a black diamond can go on the boot lid.
When the Aerocatches were complete we moved on to adding a few shims to the rear beam.
The geo for the rear beam was -1.5 degrees of camber and 10 minutes of toe on the passenger side and nearly 30 minutes of toe on the drivers side. An extra half a degree of negative camber has been added to each side and two 10 minutes to shims have been added to the drivers side. Hopefully the rear toe is a bit more equal now - but only an alignment check at in the future will really show if we have improved the geo.
Yeah similar to where mine is. Defo need to de chrome the rear.. carbon badge and tips on but basically look black.
the other Clio is coming along well! Good job lads
I do love the cup spoilers. Think they transform the rear..Yep, it could do with a cup spoiler as a final touch for the rear.
You should be able to run the wheels with out spigot rings. As they're only a locating device.Remember everyone, always check your spigot rings are on your wheels before you leave home.
Might have asked this before but how do you find the quality of the JP cage?
Thanks Ethan,We got ours second hand for about £200 which was a bargain but it was made a bit wonky. which became a bit of a problem if you wanted to run seatbelts as it rubbed up against the height adjuster thing which stopped it from retracting properly.
we ended up using a ratchet strap to bend the legs in a bit so it would work but not ideal.
i’ve heard of similar stories as well so we’re not the only ones who have had issues with them.
It works fine and they may have sorted their jig out by now but if i was buying new i would probably avoid to be honest.
Thanks Ethan,
Exactly what I have been looking for. Do you know how old your cage is it all with it being second hand?
Excellent. Thanks for this. I will avoid I think then!i bought the same half cage new, took a bit of jiggery to make it work (widening pre-drilled holes to line up properly, and similar issues getting perfect positioning to enable free movement of oem upper belt sliders).
would consider again, but would also likely look elsewhere first. less of a concern if not maintaining oem belts.. but still would have been nice if the bolt in cage had bolt holes that lined up with the chassis bolt holes..
Clio 200 glacier white | Gallery | 0 | |
S | 2010 Clio 200 with Cup pack, Glacier White, 27K miles, £8,250 | Clios For Sale | 3 | |
C | For Sale: 2008 Glacier White Cup with Recaros | Clios For Sale | 7 | |
L | Sold: 2008 clio 197 glacier white | Clios For Sale | 10 | |
??12 TBY Glacier White 200 Cup in Aberystwyth | Spotted | 0 |
