R20BTG
Holding firmly onto the Jesus handle there @burrellbloke
That was one of Ethan's friends who was taken out for a session.Holding firmly onto the Jesus handle there @burrellbloke
Since we swapped out the starter motor the Clio had been generally behaving itself. The engine works fine. The "driving" functions of the car work fine like the brakes etc., etc. I took it for a short drive to put some petrol in it in the week. It was cold and slippery on the roads but the front of the car felt odd - it probably needs the alignment done. I am not used to the bumps and squeaks that the Cup made, and that the newer Clio makes, as I have not driven a Clio for about 3 months now.
We have had a quote to sort out the rear quarter damage that was on the car when we bought it. The quote for the work is less than we sold the Recaro seats for so we are now just waiting for a date to be sorted for the work to be done. Once the bodywork has been done I can sort out the rest of the exterior of the car with a clay bar, polisher and remove off of the muck around the rubber seals etc., etc.
What I am trying to sort out with the Clio now is the internal electrics.
I had spent a bit of time in the evenings this week with the car connected to CLIP. The more I have played around with CLIP the more I have realised that it has very detailed information about the Clio. Most of my previous efforts with CLIP have involved me changing settings and just hoping for the best. At the start of the week I was getting an error message that told me there was an inconsistent configuration with the configurable computers. This stumped me until I worked out that the settings stored in the UCH were different to the airbag computer. When I solved the inconsistent configuration error message I was able to see all of the computers on the car network. What I noticed was that I could see all of the computers on the network apart from the radio, multimedia display, communications, lighting computers. CLIP can communicate with the UCH and it can save and change the settings in the UCH. The things that are not working are kind of related to the UCH but for the time being I have ruled out the UCH as being the primary problem.
At the moment the car has the following problems:
Most of these problems could be ignored as this is a track car, but the boot not unlocking is a problem.
- No electric windows
- No multi media display
- No radio
- No internal lights
- The boot will not unlock
- No auto lights
The light and light sensor is not connected to the network. The electric windows and no internal lights could be problem that we have caused when we transferred across parts from the Cup to the full fat. There is no power getting to the radio or multimedia display. The boot switch has been swapped over but is not working so I am hoping that it is an electrical signal that is the issue.
Today I went out to the Clio and found that it had a flat battery. Although I have got a PC680 sat indoors we have not done any battery relocation work yet so we just went to Euro Car Parts and bought a replacement Bosch battery. I swapped over the battery and noticed that I was swapping out an old Bosch battery for a new one and they were exactly the same. This makes me a bit concerned that there is something in the car draining the battery when it is just sat idle and not running. But a new battery rules out the issues being related to the battery.
As drove out to Euro Car Parts we cleared up some of the Cup debris and went to the tip with battered and broken parts.
We then decided to pull up the footwell carpet to see if there was any water causing problems. Straight away we found that the footwell had quite a lot of water sloshing around. We pulled up the foam and squeezed out as much water as we could. We removed two pieces which are now drying in the house.
I was keen to see if there was any signs of corrosion on the electrical wires. The wiring loom runs just under the doorway and does not sit flush on the floor. It is slightly raised and was not sat in the water that was in our car. We did find a 20p coin that had turned green so it must have been sat there in water for some time.
We then checked the big plug on the passenger side floor. Most of the plug was fine but there was green corrosion in it.
Whatever connections are in the middle of the green plug have signs of corrosion on them.
I now need to go through the wiring diagrams and see if I can work out what the wires in the green plug are for, and see if they are in any way connected to my car electrical issues.
Yes, I had to replace the Megane 280 after it collided with a deer.wait what.. you got a Yaris GR?! nice!
new Yaris GR, you now have TWO clios and have almost completed a full parts swap, and there's a subtle clio 182 (trophy?!) being used as a tip run car in the pictures above?
That’s the plan for @EthanMenace at the weekend.Remove the wires with pins connected clean then refit I have the visu disc I'll have a look and see if I can find the pins
Clio 200 glacier white | Gallery | 0 | ||
S | 2010 Clio 200 with Cup pack, Glacier White, 27K miles, £8,250 | Clios For Sale | 3 | |
C | For Sale: 2008 Glacier White Cup with Recaros | Clios For Sale | 7 | |
L | Sold: 2008 clio 197 glacier white | Clios For Sale | 10 | |
??12 TBY Glacier White 200 Cup in Aberystwyth | Spotted | 0 |
