Beany
get on it , youll have it done in a couple of hours !
yeah crack on lad
That easy done?get on it , youll have it done in a couple of hours !
That easy done?
Yeah it seemed promising. If they can take a beating round the ring with their curbs etc, they'll stand up to a beating on UK roads. My thoughts atleast.I was gonna say they are uber popular with the 'ring folk.
They look fantabulous!
I hope not [emoji23][emoji28]You’ll notice when you drive it if the cambelt goes haha
Cheers dudeWhat size V-band did you get? I was thinking of the same thing! Good work man!
Yeah to be honest I question it too!I just did a sanity check as I have a standard blowing manifold, a toyo manifold and a Milltek Sports cat in the attic, I thought the size V-band clamp you buy is for the outer diameter of the flange? As it is 3" on them all?
Edit:
So I did more digging, as usual companies are not consistent, some do indeed measure outer of the flange, so example a 3" inner and 3.5" outer, for one company you would have to buy a 3.5" v-band clamp, but for others you'd have to buy a 3" one....stupid people!
So Lewis the link you sent 2.5" is correct (well I think you could get away with 2.25" as the ID of the pipe is 60mm aka 2.35").
As when we've bought v-bands clamps for friends Skyline etc they always quoted OD of flange.
Sorry clogging up your thread!
| S | Clio 197 uch | Engine, Gearbox, Exhaust and Air Intake | 0 | |
| T | clio mk2 1.2 camshaft sensor position | New Members | 0 | |
| O | Clio 197 front spring dimensions | Suspension, Brakes & Steering | 7 | |
Fitting a turbo engine - Clio 197 | Clio 197 Area | 3 | |
Lewis's Clio 200 Cup | Projects/Progress Threads | 95 |
