Hi everyone,
I’m troubleshooting a recurring front wiper issue on my 2014 Renault Clio 4 (0.9 TCe) and would appreciate some input before replacing parts.
Symptoms:
Symptoms:
- The front wipers work normally at times, then completely stop responding.
- Sometimes they freeze right in the middle of the windshield instead of returning to the park position.
- Other times, only the highest speed setting works while intermittent and low speeds do nothing.
- Whenever this happens, scanning the EMM / UPC (11290) module shows DTC923897 / DF117 (Front wiper motor memory error / component blocked).
- Clearing the fault code via OBD temporarily restores normal wiper operation until the fault triggers again.
- Wiper Linkage: Disconnected the motor and checked the linkage arms by hand—they move freely with no binding or stiffness.
- Wiper Motor Inspection: Opened the plastic gearbox cover on the wiper motor, cleaned the contacts, and slightly bent the spring-loaded park contact fingers upward. This helped temporarily, but the issue returned.
- Direct 12V Bench Test: Applying direct 12V to the motor spins it without issues.
- Live Data & Actuator Tests (via PyREN):
- Confirmed the UCH module accurately reads the wiper stalk positions (Off / Low / High).
- Ran an Actuator Test (AC) directly from the 11290 EMM/UPC module:
- Low speed command: The motor did not move at all.
- High speed command: The motor ran, but as soon as the actuator test timed out, the wipers stopped dead in the middle of the glass instead of self-parking.
