Right. Been on here a few months now and have had the Clio since April and a lot has been changed since then. So this will be a long old start to the thread [emoji23]
After searching for months for a clio and travelling from the bottom of the country to manchester to view a lovely 200 and still not buy it. I eventually bought this RB 197 (with my old C2 in the photos)
Anyways. Came with a couple changes such as a headunit and 20mm spacers. (Which I later found were non hub-centric. )
Swapped them out.
Went to ktec for a service and discovered some issues
- play in OSF shock?
- both lower swivel joints needing replaced
- thermostat weak
- 3rd gear synchros (only I could search for months and end up buying a car that has a crunchy gearbox) god knows why I did [emoji23] doesn't change the fact I love it though! [emoji102]
Changed my thermostat and while I was in there fitted a powerflex gearbox mount. A few weeks before hand had fitted the torque mount and dogbone inserts.
Ditched the t1r ditch finders for some pilot sport 4s after some scary wet incidents.
Both lower ball joints were changed for uprated ones from raptor on here[emoji106]
Still have a knock which I assume is the shock. Will be getting changed aswell as the top mount, anti rotation links and drop links. (To keep everything fresh)
Don't have many photos of other things but I've also resprayed the nostril grills gloss black as they were a bit faded. Much better imo.
Have also changed the exhaust out for a ktec Res cat back system and the sound is unreal [emoji7] will post up videos at some point!
Need to ditch the horribly fitted cupra splitter also as I'm not a fan.
The car has also driven me to french car show 2018 and to the Netherlands, to the ring, through Belgium and France then home just last week also!
Had a blast with it over these past four months
Stick around as there's a lot more to come! Many plans and little niggly bits I want to sort!
Cheers! [emoji106]
(Enjoy the spam of photos) [emoji23]
Swapped them out.
- thermostat weak
Cheers! [emoji106]
