Update: Coilovers fitted and settled
Well on last ban holiday  monday i took to the spanners and set about fitting mt KWv3 that were  supplied by Cazan Racing (thanks @
Fernandez)
Fitting was pretty  straight forward....i mean come on if i can do it then it should be a  pretty much a pice of cake for most people
Here is the link to the guide for fitting the fronts
Click Me
First  impressions are that you immediately feel that you are closer to the  road and that there is more feedback from the steering wheel. its  slightly heavier as you would expect
The tun it feels faster but  nothing drastic from the std cup setup. I ran the std settings for a  week to let the springs bed in and then i adjusted the high speed  compression slightly to give me a little bit more comfort on the daily  drive while still maintaining the mid corner stability from the  pre-defined setings of the low speed compression. This will more than  likely be tweaked when i get to track
It feels far more stable  mid corner and also you can feel the tires working more  (if you get  what i mean). the amount of confidence that has been raised due to the  the fitting of the kit is huge. I have always been a huge advocate of  'handling before power' and this setup alone justifies that theory over  and over
As far as looks go its the BIG thing that the 200T needs from the standard from my point of view
Here are few pics that i managed to get over the course of the last week
Next up is to get my wheels ordered, Custom offset and going to have 1 spoke sprayed black
Thanks for reading
A
