330mm big brake kit
After a quick search for "330mm Brakes" on here I seen that you had asked this question before.
Did you find any definitive answers on the subject?
Not really mate. But I think I will be going for this kit at some point in the near future.
these are not 30 or 32 mm these are 36mm wide which when you get to a certain point is exactlly whats needed to creat decent cooling etc
Bigger dont mean better though as the whole brake bias becomes upset.
However I know of a few meg owners who have this kit but they run a more aggressive pad in the rear to re-sort the bias.
I also run the 2 piece kit from hi spec..works great now its fully bedded in.
With uprated pads n lines/fluid..zero fade....
You need to make a progress thread on your 200 bud :thumbup:
312mm Front, 300mm Rear.
Or as one well known Ford specialist put it to me when he had a nosey; ''What the f?cking Focus ST should've came with!!!''. :smiley:
From experiance the goodspeed discs are rubbish and dont last half as long as ta proper make disc, but i have only ALCON to compare them with not used anything else.
Alcon are the dogs danglies which is why McLaren use them :thumbup:
Out of interest does anyone have the physical dimensions of the standard renault disks, in particular the dimensions and hole positions of the bells?
Gonna make us some carbon ones Fernandez? Lol.
