330mm big front disc kit for all Megane RS models including the 225, F1, R26, R26.R and 175 DCi as well as the Clio 3 RS models including the 197, R27, 200, 200 Cup and Gordini. Testing has found that this kit wil easily fit behind the Megane RS 18" wheels but it will also fit behind the standard* 17" wheels fitted to the Clio 3 RS models.
They work with the original Brembo 4 pot calipers.
The kit uses a pair of Performance Friction slotted 330mm rotors which are made from high carbon alloy with copper and molbdenum for high temperature strength, they are then heat treated for micro structure alignment and durability. They are then tested for run out to a tollerance of less than .0005 inches. The rotors also feature handed vanes to reduce thermal warping and vibration.
The rotors are then fitted to the car using the Performance Fritction V2 fully floating mounting system. For road use this uses Belleville washers under the retaining ring to give all the benefits of a fully floating rotor but without the rattling associated with this type of set up, this keeps the brakes nice and quiet for road use. Those wanting to use the discs for a full race application can simply remove the washers. The special alloy bell design prevents heat transfer through to the wheel hubs and also means that once the discs need replacing it is only the rotors that need to be changed, not the complete assembly.
Kit was taken off the car as I found it to be a little overkill for my road needs. It also suffered from rattle that some people can deal with but I sadly can't. When investigating further it appeared the bolts may have needed tightening but rather than soldier on with that I fitted stock discs and pads so someone else can appreciate this kit for what it is - a phenomenal system of stopping power and looks.
This kit is almost £750 delivered on various websites, so grab a bargain.
Full kit including pads: £500
Excluding pads: £440
