UPDATE:
A lot has happened this week on the engine. First off was removing the piston squirters so the bores can be honed. These proved to be a right pain in the arse, mole grips just didnt grip enough to remove them. After some advice on here I started by drilling a 6.8mm dia hole into the top of the squirter, I followed this by tapping them with an m8 x 1.2mm tap, and using a 1/4 inch extension on top of the tap, this gave me enough room to rotate it to cut the thread. Once the holes had been threaded I screwed a slide hammer into the squirter and with a few knocks, hey presto they came out
Now with this taken care of the block is ready for hot bathing, honing and pressure testing next week.
I also made up a crank puller tool to finally get the crank pulley off and gave the lifters a good clean to get there "springness" back, then left the in clean oil ready for re-assembly.
A few photo's:
With all the block work done it was back on to the cylinder head and valve lapping. I managed to get all the inlet valves lapped in. Im using the oem inlet valves as I dont think the forged ones are worth it due reduced rev limit on the megane engine. I am however waiting on some supertech inconel exhaust valves, the reason for this is I think the increased heat from the increased power could have an effect on oem exhaust valves.
With the lapping I used a course compound for most the work, then used a fine compound for refining the edge of the valve.
Before:
After:
And now some engine porn
