Stephenvenning
Gold Member
I will be following this closely as I've 72k on the clock, after 4 yrs, so seriously considering upgrading performance and hence wondering about going Turbo.
Is it more problematic to go down this route, assuming Megane engine at reasonable price, or Turbo the 200 and then how far do you go??
Excuse my ignorance as I'm new to CS197, but I am not aware of the technical similarities/difference of the 2 engines in relation to the difficulty of fitment, ie mounting points, gearbox etc. also would a budget of 4k be enough to do a decent job assuming all build work done personally. If this has been covered before please redirect as I haven't found it - maybe this is the downside of 'grey-power'.
The whole problem with turboing the clio engine is the ecu doesn't like it, therefore you have to use a piggy back ecu which starts costing a lot of money. Therefore this whole concept of just putting an already turbo'd engine into the clio using the megane loom and ecu
