Yea thats the plan! Just need to make sure I get some that work with a sparco sprint xl seat that I have in the passenger side. The sw motorsport ones i have on the drivers side might not work for that seat
Do you have both mounts angled so that the floor bolts are under the seat instead of both mounts pointing to one side? Does that make sense?
For example i have the small seat on the drivers side and the outside has the floor bolts outside the seat and the inside has the floor bolts under the seat.
Feel like I’m describing that terribly! Maybe if you have a picture that would be great!
Ahh! @Big Ben which side mounts do you have? You will see my outside broken supreme mount has been turned around
Pure replied and they say the max width is slightly smaller than what sparco say the sprint L is. He said I could use 2 tunnel side mounts. But would have to buy 2 sets as it would leave him odd ones. His arent as easy to run the wrong way round as they have an extra bend
I would suggest the design is actually flawed and the slots are too long meaning that the the land between is under too much stress as well as potentially allowing forward and back movement which would saw on them.
I forget which company made these but the slot is only to allow for alignment to the fixed hole.
I agree with you there, I like the design of yours better. I’m pretty sure my drivers side ones are the same, but looking at the SW website, if the picture is accurate, it looks like they changed the design to 2 slots as well. Maybe not just as big a slots as my broken ones though
I agree, when making my own I didnt slot the rear bolt mount and kept it a fairly snug fit for the bolt with at least 10mm of material in any direction supporting it. because of the loads on that area and I used 5mm 6080 alloy so if mine do fail I don't believe it will be in this area,
My rather shady ocular finite element analysis makes me feel like there isn't enough material in that design to support the seat and drive properly.
Ever since I put all the cup racer bits on the car I thought I was missing out having the thinnest front ARB that came on a Clio (20mm). I messaged many breakers but none were willing to measure ARB's for me or let me go and measure as other cars like scenics etc came with 21mm and 22mm and they are all the same length. These can be got very cheap too.
So I ordered a cup racer 22mm ARB, all I need to do is get similar spring rates for my gaz golds as cup racers used as mine are way off (didn't know any better at the time and let them choose rates), I think this should help the car rotate a bit better. Gaz have said that the shocks wouldn't need re-valved, which is surprising as my front springs are 650-700lbs and rear are 450lbs. Cup racers run about 450lbs front and 750lbs rear according to the setup sheet I have.
