TB Rich
A little bit more woe today, the new 2.5mm to 3.5mm adapter arrived and that works fine in maintaining the correct pinning from 3.5mm to its 2.5mm end. However I still couldn't talk to the ECU.
Decided to take apart the actual USB CAN interface that the 2.5mm plug goes into. On checking how that was pinned, it also seemed like the plug was merging the CAN Hi and Low signal - so bugger it I de-soldered it from the PCB, cut the 3.5mm plug off the main lead and soldered the bloody wires direct to the PCB...had a 50% chance of getting the CAN Hi and Low around the right way on the first attempt, but success - I was at last connected to the ECU!!
Right, so lets load the firmware...follow the steps (very simple), the software tells me firmware loaded successfully.......but can I connect to the ECU any more....can I fuck! The AiM is also not seeing any CAN data either now. So is the ECU bricked???
Suffice to say a call Monday morning to SCS and no doubt will need to send the ECU back. To be honest I regret massively getting this ECU, I wish in hindsight I had gone for something like a DTA S60 and just run a whole new dash, AiM MXG which would also combine my EVO4S logging etc too.
