TB Rich
One thing is for sure. It looks awesome, hopefully the drive would eventually be on a similar level!
Home once again and yes it does look awesome!
Starting to compile a list now of things needed to get it ready for mapping, will start to tick them off one by one when I get chance to work on it. Which unfortunately is not very often as I only get every other weekend (kids!) and then at the mercy of the British weather! So I can't see it being done for a few months yet.
- Fit arch liner.
- Buy bumper clips and secure it properly.
- Drop the oil to fit the correct sandwich plate (supplied a Mishimoto thermostatic one, but a Mocal non-thermostatic one was used - not a huge issue but unfortunately for a car that sees daily and winter use a non-thermostatic one is not really fit for purpose. Hopefully the lines will still reach ok as the outlets maybe oriented differently after changing).
- Sort throttle pedal - Pure don't have a revised bracket, but it's limp and lifeless as it is. I have a solution based on using a base model dbw mk3 unit, as that has both a builtin stop and return spring. Being a non-cruise spec pedal it also has no kick down, I just need to get someone who can weld to add the upper part of the cable pedal with the clip to it.
- ECU is password locked for some reason and I can't communicate with it. Strange because I emailed the map to Jasekid so I know I did have access to it and there was no password. The SXTune software can be buggy so I'll have to ring SCS.
- ECU and data logger won't communicate, I suspect a CAN setup issue on the ECU (which I can't check!)
- Mount ECU properly and refit glovebox.
- Fit datalogger - will require cutting out the drinks holders and running a sheet of carbon over the top to hide/make pretty.
- Configure data logger - need the pinout from the loom place though. There were 3 analogue sensors I provided, oil pressure, oil temp, fuel pressure - but only 2 sensors going in to the data logger. So not sure where the 3rd one is, and without the other 2 being labelled I've no way of knowing how to configure the channels on the logger.
- Fit GPS aerial. - No longer going for roof location, going to stick it on the flat section of the sat nav screen, it's window side and will look neat there.
- Tidy up data logger and fuel pump wiring (and mount relay)
- No launch control, nothing I can do about that really. Was a communication issue because I didn't have it on my list of things for the loom place (was sent via a msg after). Tbh I only wanted it for the spark cut induced fun, so no practical loss, just a childish one.
- DBW was not done how I asked either. Single cable run with all 5 wires, and terminate with dtm allowing to swap between 3-pin tps and 5-pin dbw unit (a pig tail essentially). Now there is a dbw plug but it's quite up in the wrong place (up by oem area), annoying because it wasn't for the purpose of going back to oem - but if I later on wanted to add the Jenvey ETA unit.
- Build heat shields as the stock one was quite matty so was removed.
- Fit gearbox breather hose.
- Make a bracket for the dip stick as that's not secured now the inlet manifold is gone.
- Drain fuel tank as the fuel is 2years old, don't want to map on that.
- Change brake fluid, old now.
- Change tyres, AD08R's and decent tread but they've been sat with no rotation (and low pressure as I never re-filled after the track day) - so I'm thinking they are probably a bit buggered.
- Get an MOT! - Will need to refit the sports cat, as I still have the one made to fit the R3 manifold, however I no longer have a system to fit the cat as that was my old Supersprint which I sold. I'm thinking I might resurrect the oem exhaust for that purpose! Small bit of pipe and couple of clamps should sort that, probably don't even need to do any welding.
