EthanMenace
The nut is threaded all the way down and sits inside the black bush as well.I did but one of our guys is speculating if the cause could be your bump steer kit instead. He also mentioned the no thread on the nut as odd. Not sure why the threaded part on the track rod end is so short in general?
It does look like there’s not much thread from the top but that’s because the track rod end is lower down. There is more thread engagement with these than an oem nut.
