suj
Haha. Lucky prompt!
why do you think you’ll be limited to only -2.3°?
Top mounts on YSR coilovers, I don't think -2.3degs degrees is right, I know someone running -3degs on them (this is on large early mounts).
Haha. Lucky prompt!
I e-mailed them to double check. They said 2.3 was the maximum from their top mounts and suggested contacting Kam Racing to see if it would go further. I am sure that camber bolts could add a bit more.
Can't use camber bolts on MK3s, can get those adjustable bushes on the bottom arms, but I've heard horror stories of them coming undone and different camber left to right.
Maybe it's due to being on a 200 with later top mounts, as he's definitely using YSRs and running 3degs.
Doesn't matter now, as you've got the GGs on order, so all good.
What spring rates did you opt for?Maybe I was given duff information from YSR? I am looking forward to the Gaz Golds to stiffen up the ride on track and get the car more planted round corners.
I am running a lot of camber on my Clio and it behaves quite well on the road. So as above I’d definitely go for a better track set up and take a slightly fidgety road car
Also as a note your rear left camber is -1 degree 56 minutes. So only 4 minutes away from -2 degrees. Rather than being -1.6 degrees. (Pedantic I know but no one told me this for years lol)
@Beany has cup racer settings and I don’t think he’s a fan of driving his car on the road because it’s awfulThe Gaz Golds will hopefully arrive from Supreme Motorsport in January 2022 and I have been thinking about what set up we should go for on the Clio. We have gone for stiffer springs which are more "track spec" than "fast road spec".
The car has a set of B14s on it now which are set with a 20mm drop so it is a more compliant ride but nothing too extreme. The last time the alignment was done (with the B14s on) the set up looked like this:
After the alignment was done I added another 30 minute shim to the left rear so both rears have about 1.6 degrees of negative camber.
The ideal set up seems to be something like Cup Racer settings:
The car is being used less and less on the road and in the future it is probably going to do a few thousand miles a year on the road, be driven to and from track days, and used on track days. When it is on the road it will have sensible PS4 tyres on. The semi slick tyres will be used on track days only.
Are Cup Racer settings too extreme for a car on the road? If so, how much should the negative camber and toe be dialled back?
I am aware that by using more negative camber and increased toe the tyres are likely to wear less evenly, and, the car may not have as much grip in wet weather or on roads with "adverse" camber. What are the other things to consider as negatives for running a more track focused geometry on a car that will cover a few thousand miles on the road?
I am genuinely interested to hear what people have to say on this subject.
Thank you for all of the feedback. I think we will probably try a Cup Racer set up and see how uncomfortable it is on the road and then decide if we need to make any changes from there.
Is there an easy way to measure camber without going to a garage? I am sure that I have seen references to people doing their set up with string and axle stands. I am just thinking of finding a way to get the ride height and camber about right on the drive before driving somewhere to have it fine tuned.
You can get inclinometers that tell you camber and castor, have a look on eBay.Thank you for all of the feedback. I think we will probably try a Cup Racer set up and see how uncomfortable it is on the road and then decide if we need to make any changes from there.
Clio 200 glacier white | Gallery | 0 | |
| S | 2010 Clio 200 with Cup pack, Glacier White, 27K miles, £8,250 | Clios For Sale | 3 | |
| C | For Sale: 2008 Glacier White Cup with Recaros | Clios For Sale | 7 | |
| L | Sold: 2008 clio 197 glacier white | Clios For Sale | 10 | |
??12 TBY Glacier White 200 Cup in Aberystwyth | Spotted | 0 |
