burrellbloke
We started today by taking out the standard air box and fitting a K-Tec induction kit. The instructions from K-Tec were really good with lots of photographs and a proper step by step guide.
Out came the old air feed pipes, and the battery.
Then the K-Tec kit went in.
Once the kit was in I turned the car over and thought that the kit had made no difference at all. We were trying to finish off the install quickly so that we could catch the Racing 92 v Saracens match on the TV. When the car was stationary and idling there was no noticeable difference in sound to the car.
After the rugby had finished I took the car out for a drive and then noticed the difference between the K-Tec kit and the standard airbox. Initially the car started to idle at about 1,200 to 1,400 revs. When I drove up the road and the car got to over 3,000 revs the noise of the induction kit kicked in. After giving the car a spirited drive about I was really pleased with the sound. I always thought that my Cup was a bit on the quiet side with it's standard exhaust system but now it has a nice throaty roar to it when it is pushing 3,000 revs or above. When I got home the car was idling back around 1,000 revs and there was no noticeable difference in noise when it was stationary.
The wheel bolts had been sprayed black when the wheels were refurbished earlier this month, but as they were just sprayed black most of that paint had fallen off as the wheels had been on and off of the car when we did the brake lines and brake fluid. I had ordered some new black wheel bolts from K-Tec. Ethan put them on and torqued them up.
I then tried to remove some of the brown paintwork stains that appeared on the car after the roads close to home were resurfaced. Today I tried some Auto Finesse ObliTARate and some Auto Finesse Iron Out fallout remover. Neither did anything to the brown stains. I then tried an Auto Glym clay bar again on the brown spots but the clay bar remained immaculately clean and the brown stains did not move. I might have to concede defeat and get a professional to sort out the paintwork.
