burrellbloke
The brakes are all stock at the minute. The rears have some Pagid pads and I think that the fronts are also Pagid. The fluid was flushed through and changed last year to some Febi Dot 4. The brakes did fade a little during a track day in December 2020. I did not really expect the brakes to perform other than the they on the road, when they do not get intense use.
I am thinking about either DS2500 all round, or maybe some DS 1.1 at the front and some DS2500 at the back. For discs I might spend a bit more and not get the HC Brembo discs, more for looks than performance, and get some drilled or grooved Brembo discs.
I have got a refurb kit for the rear callipers to replace the pistons and seals but have not found the time to sort them out yet. I might task @EthanMenace with that job as he is refurbing a set of callipers for his Trophy.
When the discs and pads have been replaced I will probably flush through and replace the fluid using CLIP rather than a pressure bleeder.
