i didnt mean the short shift, i meant the standard item.
i know you reported it wasnt great when first fitted. Just like mine. But mine was a new unit, and i think the cables have no stretched and its pretty decent.
will be interesting to see what different the short shift linkage makes.
As for fueling, cant you fit a Bosch 044 pump in the tank?
Soz mate, I think it's more to do with being use to the Clio but I'm going to fit short shift mod. Yep, that's the plan to update the pump. Bosch a good option?
As for the Bosch 044, it's a meaty bit of kit that will do the job. Or a walbro 255 (I think). Both were and probably still are widely used on evo's and imprezas. I ran both and they were more than up to flowing enough fuel for 350bhp in those engines.
Only question is is if it's a direct replacement or not?!?
As for the Bosch 044, it's a meaty bit of kit that will do the job. Or a walbro 225 (I think). Both were and probably still are widely used on evo's and imprezas. I ran both and they were more than up to flowing enough fuel for 350bhp in those engines.
You'll be fine on a modded stock pump housing. The only issue is that the pressure is static in the tank so having the regulator on the rail is actually doing nothing. The 250 has a 5 bar static pressure which is obviously enough for 1.5 bar boost assuming you use a 3.5 bar reg.
I would need to see your housing to see what's possible though.
Waldro 255 is a intank replacement. What I don't quite understand is how it's regulated. I know there's a regulator on the fuel rail of the 250 but from what Paul's saying is i have a intank regulator on the clio too. I'm guessing its more about maybe looking at by-passing this regulator, but tbh I'm quite lost to a lot of this stuff!!
i was always under the impression that the pump literally pumped as much as possible to the fuel rail, then the injectors just took what they needed, and the rest was returned to the tank. Although I could massively be off the mark, as I dont have much knowledge in fuel systems either!
No fuel return on the F4RT. In the Clio, the fuel pressure regulator attached to your pump sender unit, all it does is bleed excess pressure off straight back into the tank rather than pumping it all the way to the fuel rail, then all the way back to the tank.
Ideally would be great if I could just fit the Megane 250 fuel pump.....need some pics to compare to clios....
I can't say for sure what the clio/megane setup does but certainly on new cars the in tank pump only supplies what's needed. If you constantly pump unwanted fuel to the rail you're wasting energy. OEMs want to reduce this to reduce CO2 emissions
The 250 runs a 5 bar in tank reg and a 3 bar on the rail with vac/boost to decrease/increase pressure. The clio is a 3.5 in tank IIRC so the required 4.5 bar is not available.
