Car sounds brilliant, we need to get another one of these days sorted. Gutted I missed out !
the gearbox has a magnet in it to collect metal...the metallic flakes you see will most likely be the non magnetic pieces ie bits of the synchro/baulk rings
which are usually brass
is it an issue - well it can be if they wear enough as you will loose gears being synchronised (ie gears going crunch)
UPDATE (tyres+V6 box)
Well I got my tyres on and can say I will be buying them again, takes a bit to get used to the grip and the bedding in time takes a few 100 miles not much at all! Good bye ****isports!
V6 BOX
after one failed at temped if fitting it I tyres again with some help from Angel (thank you a lot!) I bought a 90degree elbow 76mm to 67mm pipe from autosiliconehoses.com on Monday night and got it today I took 15mm off each end seemed to be enough as it fit ok but was to long the way it came, it's now all fitted and I'm away to try it out!![]()
So in short save you're self some money and just buy a V6 box a filter and an elbow haha
Alien Green 200 CUP | Projects/Progress Threads | 51 | |
| J | Alien Green 200 - £8000 | Clios For Sale | 0 | |
| C | Alien green 200 | New Members | 9 | |
| R | Wanted Alien Green 200 | Clio General Chat | 5 | |
| H | Alien green 200 broxbourne | Spotted | 4 |
