Alien Green 200 FF Cup (PROJECTORS FITTED)
TORN BETWEEN THE TOW OF THESE ATM, HELP ME!
  • Total voters
    29
It did feel stiffer when I came home but saying that it was only about a mile
Defanatly bumpier so I think so but ill tell you tomorrow :smile:
Car feels alot me settled now that before alot firmer and you can really feel the difference in the corners now :smile:
Kockhill and the damage to the oils
went to the track day at knockhill that was organised by mike, it was brilliant thank you for all the effort you went to to get it all running smoothly mike!:clap:.
the car handled brilliantly a lot to do with the R1Rs and the braces i think! no need for fancy suspension the factory items are more than up to the task, lap times were coming out at about 1:10/1:12, i thought that was quiet fast for my first time round
the backs were getting used!
i thought after being hard on her id treat her to some new oil, gearbox and engine
so this came from opie oils after only ordering it sunday night
very glad i did buy this as this is what came out of the car
gearbox oil at only 12,500 miles, how this is meant to be for life is beyond me, also looked like there was metal flakes through it like a metallic paint should i be worried?
and this was the engine oil after only 7000 miles
these are two videos i got off the go pro
http://www.youtube.com/watch?v=cMvE44-EkbE
http://www.youtube.com/watch?v=ErxSd_eo4eo
the second one is better
the gearbox has a magnet in it to collect metal...the metallic flakes you see will most likely be the non magnetic pieces ie bits of the synchro/baulk rings
which are usually brass
is it an issue - well it can be if they wear enough as you will loose gears being synchronised (ie gears going crunch)
Car sounds brilliant, we need to get another one of these days sorted. Gutted I missed out !
it was a really good day out like! ill have to see if i can get the same result if i organics one now haha, cheers still think it could be a bit nicer thinking supersprint :smile:
thanks foxy, at least its nothing major atm
H&Rs
Ordered some H&R springs ant the weekend and got them in today so decided to fit them :smile:
before
And after
Car is looking good on the H&Rs.
Definitely need to organise another track day up Knockhill. Summer holidays meant I missed this one.
UPDATE (tyres+V6 box)
Well I got my tyres on and can say I will be buying them again, takes a bit to get used to the grip and the bedding in time takes a few 100 miles not much at all! Good bye ****isports!
V6 BOX
after one failed at temped if fitting it I tyres again with some help from Angel (thank you a lot!) I bought a 90degree elbow 76mm to 67mm pipe from autosiliconehoses.com on Monday night and got it today I took 15mm off each end seemed to be enough as it fit ok but was to long the way it came, it's now all fitted and I'm away to try it out!:smiley:
So in short save you're self some money and just buy a V6 box a filter and an elbow haha
The cable that reaches the battery, looks like they still reach to the smaller battery fine? I've got a V6 airbox on the way and didn't want to have to pull at the wiring to connect it up.
EDIT: Do you also have it on a fixed bracket or is it just kind of sat on something that was already there then fixed to that?
There was one negative battery lead that I had to extend but it wasn't that much at all maybe 300mm just to give you room to move it if you needed to. And the 80amp fuse in one if the boxs the lead to it was a bit stretched but I didn't extend it I keep meaning to
The bracket is a bit crap tbh big tie wraps will do the job better that's what I used and have had no problems at all with it
No problem!:smile:
atm I'm waiting on a renflash and in the near future hopefully a super sprint or akro exhaust and long term ITBs at some point!:smile:
Na not yet Craig, But it should be in today here's hopping anyway. Andy at Ktec was really helpful about the whole thing
Epic thread mate! what a quality read, sorry about your old AG she was a pearl but congrats on the new one its even better I guess, some great ideas on there for a new starter like myself, will follow this post now haha.:thumbup:
Chambers_rs Projects/Progress Threads 5
J Clios For Sale 0
C New Members 9
R Clio General Chat 5
H Spotted 4
