This is still alive just no pictures sorry
Quick update of whats been achieved over winter so far:
Engine stripped, inspected and unservicable parts replaced.
Gearbox, same as above.
Engine and box sprayed and laquered silver with VHT paints.
Engine and box refitted to vehicle with group N engine mounts.
Full coolant, vacuum and breather silicone hose kit fitted in black.
Alloy radiator fitted.
Damaged engine wiring loom from fire repaired and reconnected to vehicle.
Coilover suspension fitted at STD ride height.
New brake discs and pads at front.
New track rod ends fitted.
New front wheel bearings pressed into hub.
To be done:
Exhaust fitted.
Battery squeezed in between headlight and K&N filter.
Coolant filled up and bled.
TEST DRIVE!!!
Then to the bodyshop for respray
Get some pics!!!
She starts too, direct off manifold so turn your volume down lol:
http://youtu.be/vMLLfPQRMvE
