Few updates from this afternoon as i got off work early so seized the oppotunity as im working the weekend too
Committment for you, as this is what i had to work in today:
Today i mainly concentrated on a few odd jobs i had been putting to one side, mainly down in the arch.
Firstly as im changing the water pump, precautionary as its run by the cambelt so makes sense to whilst its stripped down, the gasket also made a mess of the sealing surface here too, so required a massive clean up.
Required alot of emery cloth, been through a trees worth since i started the project:
Came up clean and smooth eventually though, no pre work pictures sorry:
Should seal nicely now once i've made a fresh gasket for it. Protected it from the elements until shes ready to be put back together:
Also went about changing the crankshaft seal whilst i was in the arch.
Old seal removed, note the oil pump behind:
New seal fitted:
Unfortunately broke the lower cambelt pulley trying to lever it off
£12 off ebay and another one to replace on its way
Thats all for now, thanks.
New seal fitted:
