Okay next was to mount the cylinder head up with its old friend the block:
Got a last chance to spray up the rocker cover, or more like got the misses to do it as i dont like messy jobs lol, great job of it she did too:
Even more of a shame i cracked it in half when fitting it lol
Alloy and super thin needs a light touch:
Replacement via ebay en route
Head was bolted down in 3 stages with increasing torque settings, and in 24 hours has to be completely wound off and then tightened again, to aid bolt stretching and gasket compression:
New plugs fitted:
Now timing up, got a fancy new vernier pulley for the new 1.9 spec camshaft, this will come in handy for timing adjustments in later months when i go for a Twin Carb setup
Lower pulley assembly put back on and spring tensioner setup to accept cambelt, the belt was slipped on, tension setup, 2 full rotations and reset:
Inlet manifold built back up with throttle body and injectors:
Then refitted to the head:
Arch lining put back on, wheel refitted and after 3 months finally dropped back onto 4 wheels, a day i was doubting i would ever see
Thanks for reading. Next time silicone hoses, interior and new rear boot being fitted
