Got my car back after it's little brake problem all sorted ,
They freed the rear calipers and fitted new pads foc
Now the bad bit coming home put the brakes on and a big clunk from the rear:001_rolleyes:This happened a few times when braking then suddenly stopped.
All good then i thought ,went to check the alloy key was put back and when i opened the boot the tyre inflater aerosol cans were out of the case and rolling about,How did this happen doing the brakes?
Further inspection and found a small ding in the bonnet i'm sure wasn't there before and there seems to be some added miles(20ish):whatever: and petrol consumed .Seems a long road test?
ummmmm someone had a play?
Not going there again
Phil
Phil
