UPDATE:
I havent updated this in a while due to being very busy with the engine and getting ready for the conversion.
First on my list was to get the turbo finished and get the hot side machined for the larger HL turbine wheel. The was done the same as the compressor was machined. The radius was measured and was 7mm, a tool was then made up. The housing was fixed into a 4 jaw lathe chuck with the fixture Ive made. It was then "clocked" to ensure the centre of the hole was lined up with the centre of rotation of the lathe within 0.01mm. The hole was then opened up to 46.9mm allowing 1.2mm total clearance. The inducer hole was then machined to 52.4mm. Now using the radius tool I slowly cut the contour, much harder this time than on the compressor housing due to the turbine housing being made out of much harder cast iron. Once the desired contour was achieved it was blended with sand paper like before.
The turbo is now pretty much done, just need to weld the inlet pipe on, spray it black and assemble it.
I had a big parts order also this week, Ive ordered an 60mm core intercooler, quaife ATB LSD, forge boost pipes, scorpion 3 inch downpipe, milltek centre section, engine service parts, ARP head stud kit, helix stage 3 clutch and cover and a billet lightened flywheel. Ill also be ordering all the fuel system next week.
One thing that has been playing on my mind is the hassle of sending my block out for machining and getting all the clearances right then assebling it to correct spec. I could do it but I dont really have the time considering the car is coming off the road at the end of the month. Therefore Ive sent the block off for assembly at engine dynamics. The specs will be as following:
Kings racing bearings
ZRP h beam rods
wossner pistons
ARP cap bolts
New oil pump
New oil squirters
Blueprinted and balanced crank.
Should hopefully get it back in 2-3 weeks. Then I can assemble the whole engine
Finally Ive now installed all the bearings and seals into the gearbox casings, just need to gearbox internals to arrive back from shot peening and I can finish the gearbox.
Pictures as always:
Thanks guys
