Wondered when you'd get involved. But you're wrong on a few facts there.it wasn't a total ****ter tbh, the car is still going strong now and i am bet u my lifes wages, it will out last any other meg conversation out there.
Now, on to peter, i do believe there has been wrong on all parties here but, when you work on your car you need to know what your doing your self. I believe you hooked up a couples of pipes incorrectly which then puts the car in to a "safe mode" and limits the booooooost pressure.
Now this would be one of the reason why your car was running abit under the weather. Paul charged you to swap two pipes over that took him a matter of mins to do. Also, how much were your injectors? I can get them for £200 for the set. Are you then saying you paid £600 for a remap? If so, this must be the mother of all remaps for that price. I have known for years that paul uses Henks maps. My map was a map from henk.
I cant get the bit where is slates "his own map"? So SC supposedly loaded an RST stage two map on your car (pauls known for locking his maps btw), and paul slated his own map? Something isnt adding up here?
Going from Litchy's project thread, you knew your self, to get 350/350, you will need a new fuel system, end of no questions asked.
You've wrote this email and put your car up at the same time? Do you really think people will touch it after they have seen this thread?
Paul sells them for 200 plus vat which isn't the cheapest but when you're in that position where you need them...you just have too. I would have done the plugs as well had he had them in stock.My 630cc's where £200 from the states, exactly the same as RS and other sell for double over here...
That's def not true. Andy and Henk mapped my car and it made 205bhp (****ing lousy). I took it to Paul (with a ****tier exhaust on actually and it was making only 195bhp at that point), and Paul mapped it to 215bhp. If I had a decent exhaust (i.e without the 10bhp deficit) then at the point I went to Paul I'm sure it would have made the 220bhp-225bhp the cams should have delivered. Regardless he delivered the results.
As for Henk's signatures in the Hex, as far as I understood what Paul was saying is that he uses Henk's software to map so I'm not surprised. After all Henk decodes the ECU's, writes the software and I expect as you say probably starts the ball rolling with the first maps that hit the market. However at that point I'd speculate Paul then uses those and the software but of course manipulates the fuelling and ignition tables etc to suit - and it is this that really counts not what's used to upload to and manipulate the ECU, thus leaving some signatures behind. So to suggest Paul doesn't map is simply not true.
Rich, Paul openly admits to using Henks files! Ask him! Or someone tag him into this thread. Plus I've seen it with my own eyes, I have no reason to tell lies!!!
Just time move on to newer things. She's still a pleasure to drive, but I think an upgrade is due. If I keep it I'll only be tempted to put more money into it and get more power...Thought I had a special Clio when I was keeping up with you when we were both up the top end... Awh
You still smashed everyone with the bottom end torque though, it just seemed your top end was ... lacking...
Glad it's sorted now. Why not enjoy the car for a bit? After all, you've gone through all the trouble! I can see it really gripping your anger when you look out the window and think of all that money that has gone in to the car!
| 1 | Turbo'd 197 VS Mk2 RS at santapod... | Gallery | 11 | |
Red R27, possibly turbo'd F10 ARK teesside & wynyard | Spotted | 0 |
