i thought remaps were pointless as the car seems the learn through them hence why you had problems kev. Is there still any point in doing remaps?
Its the only way I can make sense of the same mods on one car making 215BHP and the same, plus an ECU only making 203 on the other, even with all mods double checked (cams re-timed). Unless you can explain that one pal!! Im confused as hell!
We need to get em on the same rollers on the same day
Ive spoke to Matt, will get back to me!!
Maybe the yozzasport exhaust/decat setup is better, or maybe AmD are better mappers lol, who knows dude?
does anyone recommend paul at RS tuning i heard hes good
I reckon cos yours only made 188bhp standard if i remember correctly and i made 194bhp, maybe i run it in better?
Same rollers defo though, shame your all the way op'north. Maybe arrange something next PFC when im up there?
you arent the only person to have map problems kev but its interesting to hear thats what yours may have been down to. Will wait and see what results some paying customers get from remaps at tdf and then may get mine done when i am down with you putting standard and non standard against each other![]()
The best thing is to measure the difference on THE SAME ROLLERS - before & after the mods and then compare the results, and not just the end figure.
....Figures dont tell even half the story though so dont get hung up on it. How the car drives is the biggest thing you need to think about
erm...... no
If there's any difference in real life at all (and not the rollers) it can only be this. IMHO.
Do you have any dyno prints? To see where and for how long do you have the max hp&torque? Tnx
whys that then, they all used to rave about him on th CS forum.
I've just spent an hour laughing myself silly at a VEMs standalone map done there. Just as an example...target idle 1100rpm (wild cams, that's fine) lambda sensor switched on below 1000rpm, ermmmmm WTF?. Oh, here's another one, lowest load point 8% throttle opening (should have 3 lines of map below that) Idle motor function turned on.....with throttle bodies, erm there isn't one. and spark idle correction not active.
He doesn't have a clue
L | Not able to remap | Clio 200T Area | 3 | |
197: Remap London Area? | Clio General Chat | 3 | |
Remap 197 with Racechip pedal box | Engine, Gearbox, Exhaust and Air Intake | 0 | |
197 Remap | Clio 197 Area | 17 | |
Pre-cat, Y-pipe, remap ... headache :D | Engine, Gearbox, Exhaust and Air Intake | 8 |
