Its impossible to test which way around it is without driving along with the bonnet open and someone having a look while the engine is under load lol.![]()
dyno?
Any heat reflective tape placed on the rear side of the airbox ( facing the manifold ) stays on for about 10 minutes, i've tried lol.
The best alternative i could come up with is a DEI heat resistant sleeve around the inlet pipe:
Plastic has crap thermal properties, and the amount of air passing through it will surely aid cooling?
I'd also have thought if the valve is vac controlled, it will be done via revs not ECU detecting load??
i.e. it opens at 5000RPM+, so possibly you could unbolt, bend it up so you can see down it and have someone rev the engine to see what happens?
Ahh, I didn't think it'd be that sophisticated. Interesting.
I wonder if the ECU detects it isn't working the actuator then if the valve is removed and reacts in any way? Even if the pipe is plugged??
I didn't know the resonator was there.
What are the little holes for on top of the main CAF? Surely it would be better if they were blocked.
RS200 - No power, strange intake sound. DTC0340 | Clio 200 Area | 10 | |
Sprogtech Intake | Clio 197 Area | 7 | |
Power from Cams, Ported Intake mani and full exhaust | Clio General Chat | 18 | |
G | Air intake and air filter | Clio 197 Area | 2 | |
W | Air Intake Hose Hole | Engine, Gearbox, Exhaust and Air Intake | 4 |
