Thanks Tamas. How harsh is the front end? I'm thinking about 70N front and rear?
So I investigated why it doesn't tilt and slide, and tracked it down to a missing bracket on the new Madeno frames.
This is the original base frame where you can see the bracket I don't have and also the 'tab', which on my new Madeno frame bends the other way and hence why I had to Dremel the clearance...!
However this at least makes the fix easy; I have some pre-preg carbon L-shape angle I will bond to the correct distance, and cut a U shape from it to hold the plastic cable piece. Good news as it means I can have tilt and slide once again on both seats for safety.
I've spoken to Madeno and they say that the base frame portion of what they supply is from Recaro (probably from the Vanialla CS seats I would guess).....so it seems strange they haven't had these issues before, unless Recaro have changed the design :\ Anyway I'm an hour or two from being fully sorted and a couple of weeks for them to send me the RHD cover.
Also found my stickers from the Recaro Apex buckets I had........only 1 place for those
Madeno/Drivers side:
Px side:
Also found the quickest way to wash your wheels.........have another set refurbed the same colour
Nice and clean and back on AD08R for track on Sat. Front end feels keener and more responsive, so thinking now these don't cost £130 a tyre I'll probably stick with them as the all-season tyre and bin the Conti 5's off instead for an r-comp?
