The car has now been stripped of anything that was easy to pull off or remove. Some of the internal metal brackets have been removed but not all of them. There is a lot of excess wiring in the car. The one thing that we have kept in the car is the boot carpet so that when we put track day equipment in the back of the car it does not rattle around or scuff the newly uncovered surfaces.
We have a PMS drivers side foot plate.
PMS do not sell a passenger side foot plate so I contacted KIS Motorsport and they were able to see me one that was not power coated so it looks similar to the driver's side foot plate.
Ethan has used the space left by the radio to properly install the Auto-Blip and also move the traction control and cruise control switches.
The interior is a "work in progress" but we have done some rough calculations and think that we have probably removed 50 kilos in terms of plastics, trim, and sound deadening.
We have purchased a PMS engine mount kit which has now been installed.
Gearbox mount.
You can just about see the dog bone mount
Engine mount.
We did have a set of PowerFlex inserts in the OEM mounts before but the PMS mounts seem to be as solid as you can get. I started the car up with the throttle held at 2,000 revs and everything now vibrates. It is no longer possible to rock the engine backwards or forwards using your hands.
The car has not been for a test drive with the new engine mounts yet. As soon as the mounts were installed Ethan moved on to the next project which was to install some PMS top mounts to replace the Gaz top mounts that came with the Gaz Gold suspension. We are trying to get some extra caster with the PMS mounts.
We did take the car for a drive on Saturday before the PMS engine mounts were installed to see how noisy the car was stripped out and I thought it was okay. I used my Apple Watch sound meter app and it was reading about 80db when the car was being driven hard. The new engine mounts are likely to create some extra cabin noise. I haven't invested in any ear plugs yet but I suspect I might need some soon.
When Ethan look off the wheels to install the top mounts he noticed that the arch liners had been eating themselves. The car was last used at the Nurburgring and has not been on a track day since 1st July 2025.
It is obvious that when the front of the car is compressed the wheels are rubbing the arch liner away. It is not really a problem and we can run the car without arch liners. Our front set up runs slightly softer springs which we both think improves the set up of the Clio. One issue is that the bracket that holds a bolt so that the front bumper remains attached to to the arch, so that the car does not just rely on the plastic clips on the bumper and arch, is now a potential problem. On the front passenger side the paint has been rubbed away on the part of the bracket that is closest to the tyre which would suggest that the tyre has rubbed the paint off. We may need to create a new bracket or think about installing some AreoCatches and do away with the bracket.
The PMS top mount installation is on hold at the moment as some of the supplied spacers are not the right size, but we got the kit knowing that it was not something that PMS had supplied for Gaz Golds before.
The car is booked on to a Snetterton track day with MSV on Sunday 28th September 2025. When the PMS top mounts have been installed we will go back to AW Motorworks to get the front alignment done again and see how much more caster we can get. When we get the alignment done we will have the car weighed. The last time it was weighed was a few years ago and it was a hefty 1,230 kilos with 50 litres of fuel on board.
