Yesterday and today
@EthanMenace, with some assistance from me, sorted out the brake ducts that we had ordered from
@RSRowe.
We had taken off the bumper before to have a look at what space there was behind the front arch liners and I had decided that a cheap aftermarket washer bottle would be needed if there was no way of adapting the OEM washer bottle with a heat gun.
Once we had the OEM washer bottle off it was a very easy decision to go with the cheap alternative washer bottle. We decided against trying to mould the original washer bottle with a heat gun. The OEM bottle looks big when you see it bolted on to the car, but it is not actually that big when you consider that the back of it is basically folded in to make space for the motor. We managed to use the original neck filler tube.
The brake ducts were fitted to the inside of the bumper in the
fog light moulds that had so far gone unused on the Cup.
The ducts fitted well behind the
fog light surrounds that
@PITA swapped with me for my
fog light blanks.
We decided to try and fit the ducting couplers so that they fed cold air at an angle to the wheel rather than just blow air at the tyre if the steering was straight.
That was a great idea until we realised that the edge of the coupler would foul the inside edge of the tyre when it was on full lock. So off came the arch liners (they have been on and off the car a lot over the past two days) and the couplers were trimmed down.
The ducting was held on using jubilee clips to the arch liner coupler - I guess this was an appropriate use of jubilee clips on a Platinum Jubilee bank holiday weekend? We had attached the ducting to the coupler before the arch liners were fitted.
When both arch liners were in we then trimmed the ducting and put on a jubilee clip loosely on each end of the ducting that was going to be attached to the
fog light brake ducts. The bumper went back on and we used the small "service" flaps in the bottom of the bumper tray to access the brake ducts to secure the ducting tightly with the jubilee clips.
Once the wheels were back on we double checked that neither wheel was catching on the coupler on the arch liner. Job done.
I have used the good weather to soak and clean up the used harnesses that I had acquired recently.
A lot of the grime on the harnesses has come off after a soak and a scrub with a soft brush and some liquid washing detergent. As there are still two days left to the four day weekend we will see if we can remove the front seatbelts and install the harnesses.
Another small addition made to the Clio today was a Zero Point One tow eye adapter and a TRS tow loop. The TRS tow loop was drilled out to fit on the tow eye. The
tow eye cover was trimmed slightly so that the tow loop can stick out when being used. For some reason the tow loop looks really long.
