I tried to tackle the engine mount insert again by freezing the insert, using a large amount of white lithium grease, and using a large vice. It still refused to go in.
I decided to leave that project for another day as DHL arrived this morning with an early delivery from MS Custom Engineering. I think that I will contact PowerFlex to whinge about how difficult I have found their insert to get in to my two engine mounts and see if they have a a replacement that they can send out to me? I would like to get the belts done in the next 12 months before they must be done. In a worse case scenario I will get the garage that does the belts to fight with the engine mount to get the PowerFlex insert in.
The anthracite paintwork looks really good.
I am no engineer but the machining work looks good.
The throttle has been painted as well.
Before the rain arrived
@EthanMenace and I started working to get the original inlets and throttle body off. It is a fairly simple process to get the upper inlet manifold off - just remove the various bolts that either hold brackets on to it, or screw in to the lower inlet manifold. A bit of wiggling is required to get the upper inlet off as there is a metal dowel that keeps both inlets aligned and centred.
The lower inlet was a bit more of a pain to get off simply because some of the bolts holding it on are underneath the lower inlet. The fuel rail was unscrewed and the whole rail, including the injectors, simply pull out. The lower inlet is caked in black sooty deposits which I am guessing is normal after 11 years?
The engine block looks a bit tired and could do with a lick of paint - but I have no intention of removing the engine.
I am going to give the front surface of the engine head clean with some carburettor cleaner to get rid of the black deposits before the new gaskets and newly machined manifolds go back on.
Also, I will clean up the dirty ends of the injectors before the fuel rail goes back on. The photo is not particularly good but you can see black desposits on the two injectors.
If it stops raining we will see if we can get the new inlets on later today.
