Update 06.07.2014
As I was writing my last update I was interrupted by the door bell and I was greeted by a delivery driver with a selection of parcels for me.
Obviously I had a fair idea what was in them, but I still couldn’t wait to get them open. (Yes it was like Christmas arriving yet again)
A pair of dimpled and grooved discs from MTEC Brakes.
The smaller package was a set of Mintex Racing pads to compliment the discs.
I felt that when I was replacing the fronts it would be rude not to replace the rears at the same time, as the pads had never been done on the car. So a set of Mintex MDB1377 were also purchased.
Unfortunately yet more money had to be spent, this time in the form of a pair of axel stands from Halfords.
Yesterday saw me getting around to fitting the discs and pads to the car.
As you can see, the standard discs in place for the last time.
Found a good jacking point on the car that would give the best chance of getting the axel stands in place.
Cars hopefully not going to move anywhere now.
Wheel removed and just a quick check to make sure I know what I need to do.
Trying to punch the brake pins out. They were extremely hard to get moving and were by far the most time consuming part of the job.
Onto removing the calipers.
Cable tied out of the way, so they and the brake line don’t get damaged.
Now onto removing the disc. With the screws out it did take several good hits with a mallet to get them off.
Now for a wee clean up with a wire brush.
New discs in place.
Calipers now also back in place.
Pins and pads finally removed, thanks to giving the penetrating oil some time to work its magic.
Copper grease added to the new pads.
Everything now fixed firmly back in place.
The front pads had definitely seen better days. One of them even fell apart when being removed from the car.
And in typical Northern Irish fashion, when I had one side done it decided to rain on us and halt play for a bit.
The above process was then repeated for the driver side of the car, before moving onto the rear pads.
