Ive got a couple of issues which are the windscreen washer pump wont work and the rear heated windscreen wont work or illuminate on the centre console. I have tried a new pump (also wired upto 12v and it spins ok) and new wiper stalk, used a multimeter and getting no voltage at the pump connector, checked the fuses and relays which are good.
The rear screen wont illuminate with the button press and element isn't heating up. again checked the fuses and relays.
Any ideas or further tests i could try?
