Sprint Hillclimb 197
How much does yours weigh now? And what this fitting size please? Many thanks
Not sure on the current weight. But it must be pretty light for a MK3 clio now that still has glass. Next time I am at my local track I will ask to see if I can use their weigh bridge.
The fitting is 5/16th. The quick push connectors don’t work. Must use the screw on one. The screw on one is better anyway!
I used a straight version on the tank, its also 5/16th.
Reactions: VeiRoNv2
Thanks,I was thinking of replacing the plastic injectors rail with a nice billet one too,the original one is 20 years old now
Oh that would be good. With the heavier fuel hose I feel like I need to support it somehow so it isn’t just “hanging” on the plastic rail.
I think that the centre console is part of the Cup Racer dash, but it looks like it has been cut down.
Do they do a right hand version of would this be modified from a left hand one?
If you find the speedo and rev counter mount from the previous pic please let us know. Try APMotorsport for the side mirrors
Reactions: av4625
When I made the new fuel line I just cable tied it to the OEM brackets for the original lines, but that was a bit agricultural. Designed some new brackets to hold the big AN line and the OEM vapour line that has internal tracks for cable ties and screw onto the existing studs. Think they turned out well.
The car is back on its wheels now for the first time in months! Set the ride height again with the new springs as well.
