TB Rich
Reyland are fine, I've used them for a while and no issue with Pagid as blanks, just a basic oem disc essentially but at 330mm there is enough heat dissipation - crucial thing as always is the pad and fluid is correct. True they are not curved veins on the internal structure like you'll find with AP and PF etc, but I've not had brake fade with them on or off track.
My rotors are looking a bit worse for wear after its excessive 'hibernation' the last couple of years, but I remember on here a while back now someone had a set of rotors from Godspeed put on their Reyland bells as an upgrade. These did have curved veins internally, so I would simply speak to Godspeed about machining a set of rotors to suit the PF bells you have. If they can't should be able to run their whole setup but seems a shame to replace the PF bells you have. It's certainly my intention for the Reyland bells I have, and I want to keep them as they're Gold!
