the red baron progress
well today did the yearly brake strip/clean/lube and also a brake fluid change...
also replaced the broken n/s/f rear section wheelarch liner....£49! :worried:
then put the referbed wheels and new tyres on :thumbsup:
when i did the gearbox oil change i have used this time a 75w80 full synthetic oil instead of the 75w90 synthetic i had in before...also managed to get in 2.0ltrs as when i first did it only 1.8 litres came out...so i wonder if renault underfill the gearboxes???
gear change seems smoother when cold :coffee:
Did you replace the wee wheel arch fasteners also? I mangled a few of ours when I had the liners out a while back.
Is it? I have to admit that I haven't checked the manual but when I asked Tim (oilman) for which one I should go for (70w or 75) he recommended the 70w80...
http://www.clio197.net/forum/showthread.php?t=30556&page=5
I haven't changed the oil yet, should I go for 75w you reckon mate?
the renault info i have all the gear oils listed are 75w...
i would say that it depends on how the change is when cold - if its not bad from cold then a 75 porbably be ok if its like some other being a bit awkward then the 70 might be better...
i went from 75w90 synthetic to a 75w80 synthetic and the chnage is better...
i have spares but usually get them out without breaking them - i use some long nosed pliers to get under the head and grip the barbed end :foxspeed:
coming up to mot time again!
so the pads are getting changed tomorrow hopefully as they have seriously lost bite..
also going to clean the throttle body out - been surging slightly on a small throttle opening
plus a quick check over before it goes in next Wednesday for test
