I have just replaced the manifold due to split flexi. These are the symptoms i noticed.
Lower than normal MPG
Slight blowing sound (worst at around 2500 rpm)
Then one day, it just went totaly.
Bad blowing noise, It just didn't sound healthy.
Looking underneath past the cat, could see fraying on the flexi pipe
reaching down through the engine bay, running my fingers around the flex pipe i could see soot on my fingers. (Caution can be sharp bits of frayed wire down there!)
MOT emissions test - Mine was pretty close to failing on the HC test, probably due the the flexi being before the lambda sensor, so the car was injection more fuel that it needed.
Picture i took from under the car, looking up past the pre cat.. You can see the flexi is frayed.
Flexi after i took out the manifold, Split in 2 differn't places:
![IMAG0118[1].jpg IMAG0118[1].jpg](https://clio197.net/data/attachments/4/4659-7b05e29209fff764ed10ca7248349988.jpg)
