suj
So I was battling (read: deathbed) manflu, but I wanted to do a few bits on the car.
I attacked the seats first to put the Recaros in, but got thwarted by the under seat amp etc, I will attack them again another time.
I then cleaned out the PCV, but I apparently assembled it wrongly (as it pinged off when I opened it, so I put the plastic small piece in wrong, but thanks to Dystant I think I have sorted that now)....yep it isn't going well lol
But I did manage to put in the mist type washer jets, I will do a bit of write-up:
I bought these:
http://www.ebay.co.uk/itm/331793460641?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
Then I used a dremel with a rotary sanding attachment to file down the part.
Here is how it came delivered:
Then this is how much I filed off (you will do a few trips, take a bit off at a time to get a snug fit, take your time).
They work spot on, much better at covering the screen to clean better.
The link I put up above comes with a rubber "grommet", remove this when filing down the bit needed to fit, then fit it before you put them on the car, they stop the jet rotating.
Hope this helps a few people.
I bought these:
