UPDATE:
A fair bit has happened since my last post, Ill start with the bit most people wont be interested in, the alternator. I first gave the iron core a coat of anti corrosion paint to tidy it up really as i cant be dealing with rusty parts on my build. I then took the rectifier module and pulley wheel and gave them a blast with the sand blaster to remove all the crud and corrosion, I followed this by painting them the same metallic blue that the cam pulleys were painted in, to make the alternator look a little less boring :lol: turned out rather well i think.just needs re assembling now and the bearings to be replaced.
To make the rocker cover look that little bit better, i had all the bolts zinc plated which makes them almost chrome looking. This should also protect the bolts from rust, which would look rubbish, especially with all the work that's gone into this project.
Over the last few weeks one of my side lights had blown and it was time to replace, a job that I had been putting off as I dont have the smallest of hands :lol: I therefore made the decision to change them to bright white LED bulbs and at the same time change all the indicators to Osram Diadem. I must say this has really modernized the front end. These LED's are so bright! makes my projector headlights kind of pointless now :lol:
Right onto the most anticipated bit and how my turbo is going. This week I received the 9 blade HL turbine wheel from ARD tuning again, lovely bit of kit and really well made, cant recommend this company enough for td04 parts. This turbine is slightly larger than the L wheel and should make for better spooling.
In order to accurately measure the rotating contour on the compressor and turbine wheel I used a method known as shadow graphing. This is done by projecting the objects profile onto a piece of paper and then tracing the outline. I setup a basic jig with my phone light, compressor wheel mounted in a drill and the a piece of card as the back drop. two points were marked on the piece on the card at 94mm apart (2 x the diameter of the inducer) this gave me a reference point to line the shadow up with to give me a shadow double the size of the actual compressor wheel. The lights were turned off and the drill was turned on, the outline was then traced.
Using a radius gauge to curve was determined to be a 20mm radius, but remember this is a 1:2 scale, so the actual radius I have to make a tool to is 10mm. Proper engineering that
Thanks for reading.
