Stephenvenning
Gold Member
UPDATE:
As promised Ive got another update as Ive been pretty busy this weekend on the engine. Today I sprayed the alternator mounting bracket and bolted and torqued that up, marked all the bolts with tipex to show that its torqued. The alternator was then bolted in with one bolt, the other will be installed when putting the aux belt on. The AC pump from my clio will be used as I still like my creature comforts
The oil cooler was pretty filthy and ive been putting it off to clean for a while. I cant shot blast like most things on this build because grit will most likely get lodged in the fins and plates within the cooler, this could cause engine problems on first start up. Therefore out came the wire brushes and degreaser. Once clean the cooler was etch primed, then sprayed gloss black followed by 3 coats of lacquer. Ill install it once its dried sometime this week.
Pretty much finished now, the box of bits and bolts is getting less and less :lol:
