What fuel you using? Has it sat for a while.
i would check the following.
plugs
coil packs
filters
injectors for leaks
compresion test
Im using tesco momentum 99 or wat ever they call it, the better one anyway!
plugs
coil packs
filters
injectors for leaks
compresion test
So.. got to the garage after work and they had some bad news... the sensor apparently isn't the problem, that was all fine. Now they're saying its going to be pretty much £700 because its the dephazer pulley timing belt and water pump that needs replacing? so they're computer that talks to the car was saying. So i was told all good mechanics do the cam belt at this time also because you loose the tension in the belts and won't run the same putting same one back on (not advised)? my logbook is saying that the cam belt and vvt pulley was done on the 12/02/14 (before i bought it) and i got the aux belt and tensioner done on the 3/11/14 along with a service on the usual sparks plugs, oil and oil filter in december. I'm not sure if these are all the same thing or what! If anyone can reassure or shed some light that this is the problem then it would help me but i can't see it being any sort of belt that is causing the issue that I'm having?
hows does the computer know the vvt pulley is faulty?
its controlled with oil pressure from the vvt solenoid near to no1 spark plug...sure its not that that's faulty?
Dephaser is a variable pulley on the inlet camshaft, when the solenoid opens oil passes through the camshaft and into the dephaser pulley, this alters the advance on the opening of the inlet valves.
Ive not had a new camshaft sensor fitted as its still reading a constant signal so its working fine, wish it was that tho as £60 is better than 700 haMate had a cs sensor go on his too. Although if this goes it does normally mean the engine won't start altogether. Has it fixed it?
it might be worth removing the dephaer solenoid and making sure its not clogged/dirty..worth a try
and also check the wiring that goes over the top of the timing cover to the solenoid - could be a broken/worn wire
been to Trannings nissan and renault specialist in plympton, plymouth. It could be worth a trip just over the bride, thanks!Which garage did you go to ? If not been to R & S Motors in Saltash, then would suggest second opinion.
if the actual solenoid is removed you cannot run the engine as its in the oil feed to the cams/hydraulic lifters!
don't confuse the "connecter" with the actual solenoid - the connector plugs on to the end of the solenoid - the solenoid is held with 1 bolt
that holds no1 spark coil in place
Clio 197 in Racing Blue + RECAROS | Clios For Sale | 0 | |
| N | The Clio of Epic Sluggishness. | Projects/Progress Threads | 18 | |
Car Sluggish after 65 ish | Engine, Gearbox, Exhaust and Air Intake | 0 | |
| T | Anybody else 200 feel sluggish recently ? | Clio General Chat | 42 | |
Sluggish | Engine, Gearbox, Exhaust and Air Intake | 5 |
