Where you frim ripgrove, a renault specialist solved mine in the end. As for engine mounts when you got excess to the mounts make sure the securing bolts are tight and the mount is pulled forward. But if its doing it going over speed bunps i cant see it being mounts, more like suspension or drive train, a way to check mounts would be to fit a big washer to the centre of the top mount.
What do you mean about the washer? Are you reffering to how the strut top knocking issue on mk2 Clios can be solved? Had that issue on my 172 Cup and even with machining my own precise washers i never cured it properly. Will be stripping the strut tops next weekend so will have a look and maybe even fit new ones while i've got it apart. I'm down in Gloucestershire, not quite reay to pay for someone else to poke around yet until i've done everyting i can do.
Well not so good news for me I'm afraid, a guy from Renault called me and he said that there is definitely a noise coming from somewhere (WOW well done he must be a rocket scientist or something) but I'd have to pay around £200 maybe more for investigation ONLY and even then they could not guarantee that the problem would be covered by extended warranty (which is fair enough if it is a wear and tear issue).
Bear in mind that I have already paid £100 in the beginning for investigation (that was for the knocking and another issue) but the most frustrating thing is that had I known that they'd ask for such money I wouldn't have taken the car there in the first place! I'd better pay a renault specialist any day of the week! Such a waste of time but lesson learned...I'm so NOT renewing the extended warranty.
Oh dear! My strut tops are next on my list for being pulled apart, sounds like yours is engine/gearbox mount (maybe exhaust manifold knocking in the tunnel) and mine is more suspension related. Hopefully we'll get to the bottom of it all!
