Good to hear the car is on the way back to you Syer
![Smile :smile: :smile:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I'm sure it will all have been worth the wait and you'll love driving it with the remap in place
Cheers Jimmy. If only pal....
Got a call from Engine Dynamics at 3pm today and not good.
4 new injectors fitted. Car still knocking. Not just primarily on cylinder 2. But now "slightly" across the board. Whether thats changed or is now more apparent, as cylinder 2 isn't such an obvious problem i cant tell you.
Fitted new crank (?) sensor, definately fitted new knock sensor, and also tried a known working knock sensor - still no difference. Checked nothing was silly loose - as apparently the knock sensor reads somewhat from the cars harmonics.....nothing obvious. So re-checked all the settings - found nothing. Then swapped spark plugs around to see if that changed any readings [They were new]....made no difference either. Checked Renault firmware etc and was all up to date, and also cam timing looks spot-on. He says car looks genuine and honest as it should with 30k on - and nothing suggests engine has been stripped, out in its life or tampered with.
So:
Compression good - 11 bar+ he said ???
New injectors.
New plugs.
New knock sensor.
Andy at Engine dynamics is now really at a loss and cant fathom out whats going on. Mechanics of engine seem great. electronics seem good, its serviced up to date in terms of consumables and yet in order to reduce the knocking its now running 2-3 degrees LESS advanced ignition than a standard car. Says he's never seen anything like it.
I spoke to my mechanic - who used to have a rolling road and do mapping (Mainly on Jap stuff) - he said all of the stuff Andy has done sounds spot-on and the only things he could think of is a possible vacuum leak or an inlet manifold leak. Both of those would lead to a lean mixture i guess and detonation as "we" were seeing.
Andy is going to double-check with his Dad tomorrow to see if he's missing something stupid. After that the only choice is to drain the fuel and refill with fresh high octane. he says the symptoms point to....and all thats left is a dodgy tank of fuel with a truly crap octane rating. Again he said on what is basically a standard 200 with basic breathing mods - this is unheard of in terms of the detonating and now having less ignition than a standard car to run 'ok'.
If that isnt the issue he is literally completely stuck !!
