Renault Sport Clio 197 Racing Red
64mm throttle body fitted:
Finalllllllllyyyy!
Can't wait to fit it, on my way home from the postal office.
Fitted....ABSOLUTELY no issues from the first start!
Like I haven't changed the TB. Idle @900rpm from the first start.
First impressions:
-almost no more flat spot @ 2-3000rpm (had it after fitting y-pipe & decat)
- better throttle response (like I've felt when fitted high flow panel filter)
For now, I haven't felt any performance gains for.now but I believe there are some because of the missing flatspot.
A worthy mod.
Will write some more when I get back home.
[YOUTUBE]JWGSDxELoAw[/YOUTUBE]
Met a friend on the road and we did some 50-200km/h runs and a photoshoot:
Too bad my car/wheels were dirty. :wink:
Finally:
Bought Torque too. Can't wait to try it out. :smiley:
Wasn't happy, to say at least, with the carbon wrapped centre console that one company did for me so I've painted my old carbon look vinyl console, dash strips and A/C ring in black. Looks much neater than it did before (vinyl started to unglue).
Took me whole day to remove the centre console, dash strips, paint & reinstall the DVD player (the hole is barely enough to install the DVD so I had to remove the A/C control, glove compartment and battle with excess cables).
Painting process:
It has been 10 days now after fitting 64mm TB and I have to say I absolutely love it. :thumbup1:
The car feels much eager to accelerate - like it was breathing through a straw and now it doesn't any more.
Unfortunately, I haven't got the chance to try out with my friend and his CTR EP3 to see any true gains on the road due to the fact he had installed a performance exhaust system so he's no longer a real reference to me.
Had the car on the dyno before/after like I said I would. The TB was on the car for 3 days before the dyno.
This reading I've found confusing - much more WHP increase, but not that big BHP (probably due to different weather conditions - temperature, air pressure,...):
And the other thing I've noticed - the car is running leaner than before (I can see the exhaust not getting black after pushing the car hard, and before the TB it would be black after 2-3 hard runs) so the next thing is a remap.
My current setup:
V6 Ph2 airbox with K&N panel filter
matched/ported inlets
64mm TB
lightweight flywheel
Y-pipe
Miltek decat
Miltek catback
remap (not suited to the new TB)
New thermostat - my old one used to be open most of the time so the coolant temperature would vary often at cold weather:
Is that only 148bhp? Or am I reading that wrong? Because if i'm not, something must be seriously wrong there.
Should be better/higher but my tuner is very conservative, he thinks that I/we drive hard everyday...:smiley:
Will have the car remapped to suit the 64mm TB in the next few weeks because the car is now running lean.
Views on Y pipe?
I can't recommend it or not recommend. :smiley:
PRO:
- amazing sound - exhaust keeps popping, raspier sound...just great
CON:
- big (not massive) flatspot 2-3krpm, however, once you get used to it - you learn how to minimize it. :wink:
With the 64mm TB I have managed to get rid of 70% of the flatspot.
Performance? Hmmmh...TBH, I really don't know if I got anything with it because I had other mods in the combination with the Y-pipe done at the same time, and still believe I can squeeze more bhp/nm with a remap.
If you ask me if I would put it on my car again - probably YES.
If I manage to get 195-200bhp out of it on this rollers I will be VERY happy because my car is already 40-50m in front of the stock 197 50-200km/h.
I've expected it to be really dirty given in mind that I haven't changed it in the past 15-20kkm but not this dirty..:wink:
Changed the upper engine mount & the lower engine (gearbox) mount.
First I've changed the lower mount and the difference was awsome! The engine had atleast 60% less
movement on throttle release than it had before. TBH, I bought this mount just in case if the OEM one wasn't good and I didn't expect that much of a difference.
Old one:
Notice the cracks...
New, Swag one:
However, I've expected the big difference when I changed the upper one but it was not as nearly as big as when I had the lower one replaced.
Old, OEM one:
New OEM one:
Now it feels as good as new on throttle release.
And yes, I was on a track day @ Grobnik race track. Haven't planned it till the last day (old CSC3 DOT2410 tyres, only 2mm of front TRW brake pads) but I haven't been on the track for 2 years so I went.
I wasn't pleased with the time I made. Was 1.3s slower (1.56.9xx s) than 2 years before. Totally disappointed. :worried:
Did only 3 fast laps, and 5 cooldown laps...:wink:
Stupid...:thumbdown:
[YOUTUBE]J7IHxwrt0BM[/YOUTUBE]
