VeiRoNv2
It’s out, it’s finger tight that’s the problem, the threads in the caliper are destroyed and it’s just sitting there loose and can’t be tightened
shit thats even worse,will you try to Helicoil it?
I’ve sent them to MS Custom Engineering. He said it would be either a helicoil, a bigger insert or a bigger bleed screw.shit thats even worse,will you try to Helicoil it?
+1 on this issue, removed a driveshaft last night and noticed the same thing after our 1 trip to cadwell.I noticed when I was doing the brake cooling that the dust boots on the SuperPro anti-rotation links were cracking and perishing. I'm replacing these before they split and lose the grease inside. I called up SuperPro (Octane Distribution Ltd) to enquire about spares.
They are £6+VAT each (!!!!!), plus a £5 delivery charge, which quite frankly is a piss take for a small rubber dust boot. So here are the dimensions if anyone else has the same problem and wants to source some universal ones that might do the same job:
11mm internal diameter top hole:
25mm diameter bottom hole:
30mm diameter at the widest point:
25mm height:
18mm top hat diameter:
If anyone finds some, do me a favour and buy a handful for me as well, as this seems to be a known problem and the original ones are shite, this is probably an annual service item now![]()
200T: R200 CHJ | Spotted | 0 | |
200: White 200 with R200 plate New Lubbersthorpe, Leicester | Spotted | 0 | |
Car reg for sale R200 TBM | Car Parts For Sale | 2 | |
Old timer making a return.... UR200! | New Members | 43 | |
197: Red, Iveson Drive Leeds 16 R200 T*T | Spotted | 0 |
