jimmybell
Hey guys, got a pair of pole positions, and a set of the recaro side mounts.
wanting to know what i need to adapt the side mounts to the clio?
also thinking drivers seat would benefit from some slide rails to adjust in case some short arse people i know want a go. Not really sure which rails work for this and the above adaptor? And ideally are pretty low profile to minimise additional height.
Passengers can just be fixed and deal with it :d
also ive read a few places some mounting plates can offset the off-centre wheel?
is there any harnesses that wouldnt work with the jp bolt in cage’s harness bar - Im thinking of going with the schroth 4 point?
just need to work out how to use them and still keep the oem seatbelts - there seems to be a few types of brackets that sit under the rails but hard to tell which fit (and what are the middle two bars for on these)
www.sportseats4u.co.uk
Endurance Motorsport seat belt brackets > GSM SportSeats4u
These seat belt brackets are designed to work with Corbeau, Cobra, Sparco, OMP bucket seats. These brackets allow you to retain your standard seat belt clip and seat belt without the need to use harnesses. The brackets fit between your seat and your sliding runners. We've designed them to work...
