@Pav your issues go beyond needing water wetter mate.
it does,doesnt it?was thinking that too..much better colour imo..Pav, sorry to hear about the struggles with the heat, something we're all having to deal with right now! You'll get it sorted I'm sure. At least it's running well now so you can enjoy it.
Great pics though! Look how much better Albi looks next to that BMW blue!
i certainly did Jimmy but in all fairness,there wasnt much to look at..families with screaming kids so you get the picture..Looks like a nice day out Pavster - glad you managed to get somewhere in the end. Hope you took your sunglasses to the beach, so you could 'enjoy the views' subtly
Sorry to hear about the high temps bud, I hope Trevor can work his magic again. This heatwave definitely won't have helped, but you know the witch inside and out, so you'll know when she needs some fettling....
Syer I spent a few hours on youtube last night looking into these additives..they arent bad at all from what i saw..may get a bottle and throw it in since it can be mixed with water and antifreeze..cheers for that buddyAgreed ! Seeing as Pav had already stated he would be contacting Trevor; and the fact i said i'd leave the mechanicals to him - i thought t was obvious my suggestion was a potential aswell-as : not an instead of.
Sorry if anyone misunderstood that.
it will be fine its just stopping me from booking a track day again and spending more money on her..its never ending thisMinor roadbump mate - don't fret![]()
tried looking everywhere..no puddles or visible leaks anywhere..will be ordering a new radiator soon..also got 10l of distilled water and some rad flush fluid to flush the system..see if that helps..thanks for any inputHello Pav, I have the same problem with my Clio. I also a new megane radiator, but that didn't solve the problem. I've found a very small coolant leak though, I think it gets some air in the system via that leak. Maybe it's worthwile to check yours for any minor leaks.
again..not my preferred way..dont really want to cut a hole in my bonnet if you know what i mean plus,dont think its cheap either...but thanks for this BenBonnet vents an option maybe?
Think Sean was contemplating some
sounds like a daft question but is this the one blowing hot/cold air in your footwell area??
Furry muff. Pavs engine sounds like ityeah I thought about it, but once I'd actually driven the car properly in anger (full day at Spa) I realised I didn't actually need any.
Not quite cooling sufficiently then.
How are you measuring the temperature so accurately Sean?it's a strange one. If my clio rad is cooling mine enough then Pav's megane radiator should be working fine, especially with no leaks. It certainly shouldn't be over 100degrees when mine is only going up to 92!
Have you installed an external gauge?
no thats absolutely fine..its blowing a very hot air mate!!very hot..think i could fry eggs in my cars just using the bloody airdoesn't matter, just put the heater on full hot and full blast once the engine has warmed up. If it's blowing out cold air even when the engine is up to temp then the system needs bled.
| S | New owner Albi Blue 197 | New Members | 13 | |
| I | New Irish Member Albi Blue Clio 197 | New Members | 1 | |
Albi Blue 197 Near Duxford | Spotted | 4 |
