Had a trip up to RS Tuning today. The original plan was to fit some 630cc injectors and get a map to suit. Unfortunately we had a bit of clutch slip so it was decided to ditch the upgrade plan for the time being as wouldn't be able to get the map on with the clutch as it is.
On the initial run it hit 291.7 bhp. However, the injectors were at 107% duty and the fuel pump at 114% so in the interests of keeping things safe a Stage 1 map was applied until I decide to either sick a meg box in it or replace the clutch in the Clio box.
I will also need to replace the fuel pump with something more sturdy and will probably go with the same one from shaky as Litchy has.
So for the moment the Mistress is now running a modest 258.1 bhp and 275lb torque. Tbh it doesn't feel any slower but does feel a lot smoother.
Just need to decide what I'm doing about the gearbox situation, the gearbox itself is ok just the clutch struggling with power. So I either get an R26 box with uprated clutch and single mass flywheel or continue with the clio box and get a diff.
