Maggi's 200T EDC
Tempted but £200 for a cone filter:zomg:.......... (it'll happen at some point :clap:smile: just waiting to see what the ITG induction kit goes for
The cost is for the bracket/heat shield really. It sounds good, more grumbley, more popping off throttle in sport/race, LOTS of turbo whooshing and chirping. A quick drive has revealed it's loud enough for people to turn around if you're a bit of a bell coming off throttle on boost. In fact it's addictive and I've seen my mpg plummet. It does still use the oem cold air intake, which I guess is nice.
The itg kits are out pal have been for a little while very good quality and sound very nice I have done a conparison on Facebook pal
I like the cone design, don't think I could put up with the recirc chatter/whoosh noise coming back through the cone though. Would get on my tits making that noise for a whole journey soon as you come near any boost.
Found a moving vid of similar noise
http://youtu.be/mwZJFShQfoI
Is it just me that's not a fan? Just seems a bit ott?
There's a piece of rubber that sits inside the hole on the outer edge that the guide pin goes into, I used needle nosed pliers to pull it out on the drivers side that was giving me agro as it was too far in and stopping it going back in properly. I then placed it on the edge and it went in no hassle.
Would be better if it was more like a rubber grommet you had to put the pin into but I guess it works as it is.
Need to find some bulbs for the fronts, the ones I've found so far are bmw specific and not exactly cheap
turns out out I have a broken rear cluster on mine dealer tried a new clip didn't wk so going back Saturday to try a new clustercluster
It's nothing like the corsa in reality. The turbo is now amplified through to the cabin via the bar behind the dash, so I intend to blank it off this weekend and see if that makes much difference. It made plenty of noise before anyway, just slightly exaggerated now.
